Cleaning Inside Of Mineral Glass
ro63rto
I noticed a sort of fogging on the inside while playing with my LED torch, charging up the lume on 3 of my watches, Sector 155, Breil Ducati One and Seiko Arctura.
I have 100% Acetone, Switch cleaner and plasma tv cleaning fluid.
Are any of these ok to use on a q-tip?
If not, anything else I should get?
I would try using a weak solution of washing up liquid with your q-tip first. It should remove it and there is no chance of melting something in the process. I certainly wouldn't use acetone ar switch cleaner, the plasma tv cleaner would probably be OK.
Hi ro63rto,
Whenever using a q-tip be careful with the lint it leaves behind. I clean my crystals with Windex but never "spray" directly. The lint free paper and the blower -- even sometimes a dial brush to pick up the lint -- assure a lint free result. Also mind humidity and rubbing if there is a chapter ring held in place between the crystal and the case. Sometimes it can get cracked, discolored and otherwise damaged. The humidity left behind by the cleaner may fog the watch after closing it. Also if there is any spot where the q-tip catches on parts, it could dislodge them and/or damage them...this is mostly seen when used in dials which is not your case....but I like to be thorough. :)
During cleaning I tilt the crystal to different positions, observing it through the light. Mind that some Seiko crystals have a coating on the inside that should not be touched according to them, only the outside.
Cheers,
Bob
i may be missing something but fogging on the inside of the case would indicate that the watch is not sealed? - like i said, sorry if ive completely missed the original question.
You are right in asking but this fogging is unlike anything I've seen. Normally on a non sealed watch I start to see a circular foggy patch in the middle of the crystal.
These look like someone has wiped the entire underside of the crystal with a sweaty finger.
....it could be a lot of humidity or water might have actually gotten in (hot showers are the worst, etc)...is it actually wet?
There is the dust and the fogging due to age, expired seals, etc. So far, the recipe given was to clean the crystal...
For humidity you still need to clean the crystal but a good service and detection/fix of the unsealed spots is necessary...normally replacing o-rings, gaskets, silicon grease, etc will fix the problem...at least that's what I do. Pitted and rusted joints may require more work or impossible to seal completely...
Opinions/how-to's are appreciated to help improve!
I can safely say I have never worn any of my watches even while washing my hands let alone in the shower or while swimming.
I did notice that the Breil has what looks like ice crystals. Have to use a louoe to see it.
I will check closely for moisture signs when I open them up and remove the movements though.
Fogging on the inside of the lens is no good . Could be a bad gasket or you have pressed a button on the watch when it was wet .
When i assemble  a watch the last thing do is use a camera lens cleaner . I buy them on Ebay . You could buy them on Cousinsuk . They are much cheaper to buy a dozen from China . It has a little sticky round cleaning tip in one end and a brush in the other . http://www.ebay.com/itm/3-in-1-Kit-Lens-Cleaner-Pen-Dust-Cleaner-For-DSLR-VCR-DC-Camera-Nikon-tool-FO-/291317706237?pt=LH_DefaultDomain_2&hash=item43d3e36dfd
That looks quite useful.
I have the usual blow brush in my camera kit but it doesnt have that other bit.
Thanks.
Thanks.
Inexpensive but do the job nice . Hold up for a lot of watches and it has two sticky sides in one end of the pen . Remember to throw it in the plastic recycling basket after it has been used up .
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
