To clarify, could you post a picture of the actual part that is giving the problem? It sounds like it is the cannon pinion that is rusted to the arbour it slides over.
Bob, a Landeron 47 is a chronograph movement. ;)
Edited by Geo
Thanks Geo, I'm not sure about the number, that's why I ventured a 47 which seemed about right at the time, now I know better. :) It has the looks of a Landeron though, maybe it could be located through ranftt ? Just a thought.
That's on the plate clockboy, and I'm glad you confirmed it since I couldn't read it well. In fact, because of it, I searched instead by the brand on the dial (not optimal), and came up with Landeron. Maybe it is a similar ebauche? Very intrigued myself too.
I'll follow the thread with interest and see what come up. If I find some reliable information then I'll report back.
Cheers,
Bob
This is all a bit confusing Jerry, the pin should be solid inside the wheel and the cannon pinion a friction fit over it. The cannon pinion should carry the minute hand. The hour hand should be on the hour wheel and driven by the minute wheel via the cannon wheel.
Edited by Geo 2/3/15
The above information is incorrect for an antique trench watch. See post dated 2/3/15 for correct information.
Edited by Geo
Looks like the pin is bent & canon pinion is damaged which is not very good. As Geo says the pin should be attached to the wheel.
Edited by clockboy
Probably a Langendorf movement as Lancet was one of their names along with Lanco. I think you might struggle to find another so you may have to try some type of repair to what you have.
Sorry about the mix up. I confused the avatars (should have read) and meant Jerry but nice to have your input too clockboy! I'm learning here from what you, experienced friends, are sharing.
Cheers,
Bob
the minute hand rides on the pin..not the cannon pinion
If this is the case, the hour and minute hand will go out of register when you adjust the time with the crown. Only the hour hand will move!
if you have access to henry frieds  book "bench practices for watch and clockmakers" look at page 236...he has a diagram relative to this arrangement
I wish I did Jerry, I'd like to see it! :)
the pin at number 01 slides out in the direction of the number 02...the cannon pinion is friction fit on the pin...the minute hand rides on the pin..not the cannon pinion
My statement above regarding the operation is correct regarding modern watches, but as it turned out it is flawed when referring to old pocket and Trench style watches. For this I must apologise.
Having just completed work on a 1913 trench watch, I now know how the cannon pinion system works on these old watches.
The pin No.1 in the picture is a friction fit inside the centre wheel No.2 in the same way that a modern cannon pinion is a friction fit over the centre wheel shaft of a modern watch. If need be, this fit can be increased by gently peening the part of pin No.1 where it locates inside the centre wheel No.2. This could be done until the required degree of resistance is attained for setting the hands.
The cannon pinion in the trench watch has a slight taper inside, and pin No.1 has a matching taper on the part that is exposed above the main plate. The cannon pinion when fitted correctly is a tight fit on the shaft, just like a morse taper, and does not rotate on the shaft. The hour wheel is fitted over the cannon pinion and is driven by the cannon pinion via the minute wheel. The minute hand is fitted tightly onto the pin No.1 holing it all together. There is no dial washer!
The hour hand is fitted in the normal way, but I recommend using a staking set to fit the minute hand accurately. Select a position on the die plate between holes, or use a flat faced stump to support the lower end of pin No.1. A flat hole punch should be selected for driving on the minute hand. This should be done very gently using a watchmakers hammer until it is fully seated. The end of the pin should just be showing through the centre of the minute wheel when correctly seated. Check to make sure that the hands are setting correctly and all feels good before casing the watch.
Good research Geo.  Interesting set up that I have never came across.
Not research CB, that was what I found when I stripped and reassembled the watch.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
