New member from the UK
By EtherJunky · Posted
Oh that is lovely, thank you. I also just cracked the crystal and lost one of the shock absorbers, so its gone in the separate baggy of 'maybe-one-day' 😄 I did learn the valuable lesson of not disassembling the shock absorbers. My next one is a Zaria 1509B. I think this one I'll take a bit more time with cause I'll need to source a couple of bits. It's also scary teeny. -
More data on the oscillation tests: Vertical: 15-20 seconds…Abysmal Dial up: 1 min 15-30 seconds Any thoughts @nevenbekriev @JohnR725? My next thought is to oil the balance jewels to see if that helps. It’s certainly one major thing left that I haven’t done.
Hi. Once the pins have been withdrawn the brace let comes apart, never had a problem with these. -
Hello and welcome to the forum added the racketa 2603 sheet incase you don’t have it. 4328_Raketa 2603.pdf -
Hello and welcome to the forum added some reading for you. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
