Russian Trio
atimegoneby
I recently purchased a trio of Russian watches to add to my modest collection,
I bought them directly from Russia and the first to arrive was this unusual one handed 'Luch', the dial is marked in 5 minute increments, it's a manual wind with 15 jewels and runs for around 43 hours on a full wind and is surprisingly accurate ! .    :)
I quite like that, although it took me a couple of seconds to get over it having just one hand.
There is a simplicity about it that is very appealing and the idea of a pace of life that demands no more than 5 min increments on the dial is very attractive.
The second of my trio to arrive from Russia, is a Vostok komandirskie, it has 17 jewels with a screw on back and screw down crown,
the quality and finish of this watch is far better than I expected and I think is actually quite superb, the paperwork guarantees accuracy to -20 to +40 secs per day but when I check it against my radio digi clock it usually gains 5-10 secs in a 24 hour period which I think is pretty good ! it runs for around 42 hours on a wind and when setting the time, with slight back pressure you can pause the second hand
( I think they call this hacking ). Overall I think a great watch especially for the money ! .    :)
Atimegoneby,
I don't suppose you can post a shot of the movement in the one handed Luch can you? I am intrigued every time I look at it. I had assumed that it would have a standard three hand movement but with only the one hand fitted as this would allow the use of an existing stock design. However, a jewel count of 15 is a little unusual for a modern watch unless it's design has omitted one wheel from the standard layout, which you could do if you only have the one hand. That would require designing and tooling up for a new movement though which would be a very expensive exercise, particularly for a watch that is likely to have a fairly limited following. So I'd love to know what's inside.
Just had a look at the RLT offering and that appears to use an ETA (Unitas) 6497 or 6498 with just the hour hand fitted.
I think I prefer the more "instrument" look of the Luch though. I'm just curious about the jewel count though.
I love the one handed one! The first time I saw one I thought how on earth does one tell the time but after a while I realized how easy it is to tell the time. I must look out for one of the Russian made ones, thanks for showing your lovely collection.
Thanks for looking, glad you found them interesting .   Phil.
Hi Marc,
The movement in the Luch is very small with a plastic spacer to hold it central in the case,
I did some looking on the net and apparently the movement was originally used in a small ladies watch, and thinking about that I'm not sure whether such a tiny main spring would have the power to drive two large hands ?, I'm sure Mark would know the theory on that ?
don't know the reason for 15 jewels though ?
I've also seen another version where the dial looks like a vintage car speedometer and the rear case is engraved with an old Russian car ! quite curious.  Phil.    :)
Thanks for the pic Atime, not what I was expecting though. It looks like the Luch 1800 or 1801 which is a ladies watch calibre and was always a 15 jewel machine. Despite its diminutive proportions though, capable of quite respectable performance.
The "single hand" concept has got my interest now. I am thinking that a future project may be to put one together my self. ETA 6497 or 6498 based (or more likely a seagull clone at a fraction of the price) in one of the off the shelf pilots style cases. I would probably need to fabricate the hand and dial myself which would be fun. I have seen a number of articles now regarding DIY dials using water slide transfer ink jet paper and acrylic lacquer with excellent results, although I don't know how UV durable the dial would be. Maybe if I found it on my wrist often enough I could get a "proper" dial printed, although that would probably double the cost of the project.
Certainly one to add to my "to do" list.
I'm thinking more like the Seagull TY3600 which is pretty much the same thing for around £26 + VAT, also from Cousins. A no-name stainless steel case with mineral crystal and display back off ebay for about the same money, and some 0.3mm brass stock for the dial blank. Probably do the whole thing for less than £75 for materials. Then it's just the fun of pulling it all together.
From what I can gather the Seagull movement is actually very good and any differences that there are between it and the ETA offering are nowhere near enough to justify 7 times the price. You could argue that in a watch that only has an hour hand even the Seagull is over kill since as much as +/-60 seconds deviation per day would go unnoticed for quite some time.
Well this took a more rapid turn of events than expected.
Having costed up a Seagull TY3600 and a case at around £75 separately I spotted this on ebay.
A Seagull TY3600 in a suitable stainless steel case, brand new, for £26 + £4.95 postage.
The crystal on this one looks awful but that's because it has a clear plastic sticker on it.
So project started rather sooner and for less than half the price than envisaged. :thumbsu:
I now need a non-seconds hand fourth wheel, and then to make the dial and hand. If I keep all of the original parts I can always return it to stock if I want to. Not sure when I will tackle that part of the job but I will post my progress when I do.
Incidentally, there seems to be a number of these on ebay starting at 99p on a 2 day listing and ending up between about £20 and £30. If you're on the look out for a big watch on a small budget these have got to be worth a look. I checked out a couple of user reviews on the internet and they seem to be well received. Search for Detomaso Savona; the buy it now price seems to be £99 so look for the auction style listings.
When mine turns up I will give it a couple of days wrist time and then post my impressions.
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
