Today's flea market finds
easj369
I'm a sucker for older Seikos and stumbled upon this today.  It's very clean inside and out, didn't have a band on it but had this one laying around.  I think the black chapter ring gives it an extra kick.  Also got this Bulova from the same seller.  It's currently not running so I now have a project for tomorrow. I haven't had a score in a while,  but for $20 for the pair I'm satisfied for a while.
18 minutes ago, anilv said:
Nice ... the Bulova will be challenging as these small movements have super small parts and fine pivots.
The Seiko is a real beauty.
Anilv
Thank you.   Yes those Bulova movements are a pain.  On the upside though I have two parts moments for this one.  The stem doesn't pull in or out, it rotates but does nothing.  So I have a starting place for it.  The balance is good though so that's a plus.
What does it think it is? A Sekonda? I've seen a couple of USSR era Secondas with almost identical issues, but not a Bulova. I suspect that things got a little tarry in the keyless works, and someone decided brute force was the answer. Presumably you have enough bits to make one good mechanism.
    • Surely it depends on the clock , I only usually restore torsion clocks and I only use oil on mainspring ( small amount) but on the few so called normal pendulum clocks I have done I have used mainspring grease as there is more reserves of power than there is in a torsion clock so it is not so critical. Dell
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
