how to remove this crystal
so im working on a tag heuer super professional , with a one piece case
i hav troubles removing the crystal and i can't see if its glued  or not .
I tried a crystal lift but this did not help at all
any tips?
thanks
It will probably need pressing out from the inside with a crystal press.
Something like a Robur press and dies
Sometimes It's best to use the aluminium dies rather than the felt covered bakelite ones, as the top dies are more for using with acrylic crystals, but I have used them on flat mineral glass when pressing out of and into a case
As Nucejoe says It will have a split stem  once removed a sryinge is used to pump air in via the stem hole, this will blow out the crystal under pressure so make sure the watch is covered, attached is the Bergeon pump but a normal syringe (Ink Cartridge refill) and a piece of plastic to make the seal around the stem tube can suffice.
BERGEON 5011 Watch Pressure Crystal Removing Pump.html
Hi  I too fail to comprehend, as the stem has no control over the bezel or glass, I can understand if it was a loose  fit and manhandling the watch to remove the split stem you have managed to dislodge the bezel,  I should check carefully when reassembling the bezel and case that the bezel is tight.
