Loose clasp on bracelet
By rjenkinsgb · Posted
You could get one 3D printed in stainless or titanium? Add the rest of the original detail to your existing model and proof check it comes out OK in plastic, then have it done by JLC, Shapeways etc. Not cheap, but you could get a lot closer the original appearance? -
By LittleWatchShop · Posted
By Sebastiaan · Posted
Thank you for the reading material
