I’m refurbishing a Seiko 7T92-OJSO for which I have ordered the correct 36mm x 3mm thick crystal and gasket.  I have a crystal press but have yet to use it to push home a crystal into a crystal gasket so I have a question - should the crystal be pushed in dry or should I lubricate the gasket with silicone grease or similar first? TIA
I would push it in dry as lubrication could allow it to slip out. If there is a bezel ring to hold in the crystal, then i would apply some silicone on the gasket.
Thanks, no bezel ring on this design so I guess dry insertion is the way to go.  Cheers
Hi I would consider       JD's advice . they are a dry fit but be sure you get it all square and seated correctly before applying pressure the last thing you need is a bent/crushed gasket.
