ETA 2081-2 Movement.
Hi
I have a Stocker & Yale Military watch with the ETA 2081-2 movement. A part in the winding mechanism is bent preventing stem insertion and setting and winding. Does anyone know of a source for parts for this movement or if another movement has part that is interchangeable.
Thank you,
Tony
Hi Tony, A popular data base to start with is Dr ranfft's, google like this eta 2081 ranfft, the entire family of this caliber and bunch of relevent info gets cranked out. Another data base is julesborel.com which lists parts in detail.
When you say it's bent and prevents the stem to be inserted, is it the setting jump lever (8) in the picture you mean?
It doesn't look very bent to me. Just out of interess, could you take a picture with everything assembled in the keyless except for the minute train bridge (30).
I attache the tech sheet so you could see which parts I mean, the definitions are ETA talk.
_C_T_CT_2801-2_FDE_481538_15.pdf
On the most modern ETA 28XX -2  parts from the keyless are the same .
If you by some reason aren't allowed to buy the parts you need later on you could always send a private pm to me.
It is hard to see it is bent since it is laying flat. When I say it won't set or wind, it is because I can't insert the stem. When assembled, pushing on the tab to insert the stem causes the works to pop out of place. However, if I insert the stem in place, and then assemble the rest of the works, it will set and wind. Then when pushing on the tab to remove or insert the stem, the setting lever jumper as well as the setting lever pops out of place.
Also, thank you for the information about the other ETA movement.
Tony
Edited by spiro13
When you take the stem out you shouldn't push the lever nob with a pointy device. If you do the risk to push it to far is imminent.
If you turn it around you will see it has a sloted shape where the lever pin sits, when you will take out the stem you gently push with a screwdriver which fits in the slot. Doing so will prevent you to push it too deep and pop the setting lever jumper out of position.
the setting lever jumper should lay flat on just as it does on yours so that one is not yet a gonner you can just bend the most of the levers slightly downwards when putting it back together, my picture is from a 2824-2 but you can see how it should look like. (except for the dirt ; ) )
Edited by HSL
HSL
The keyless works is operating. Not as smoothly as I would like but it is functional. It took some delicate bending in two places to achieve it. In the mean time I'll keep looking for a replacement.
Thank you so much for all the information you gave me. It was most helpful.
Tony
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
    • Thank you very much,T. I'll try turning the arbour from the clock face end very carefully in case I haven't reassembled the suspension block correctly (I had to make up a suspension spring using remnants of a broken one as I haven't been able to find an exact replacement online).
    • Hi murks a picture of the front as well would help,   By the size of the plate it was stuck to I would suggest a coin cell,  2030,  2015 all depends on the height of the cell. And the space when the back is fitted.         3 volt.
    • We seem to have gone a bit quiet on this ?  Do we all agree to ask Mark for some input on this matter, or is no-one really bothered.
