Victorinox 241321 stem crown?
Post a picture of the module to identify it. Then you can consider buy a replacement or take it apart to inspect and fix the keyless works. Check that you can still screw back stem to crown.
8 minutes ago, Merlynda said:
I didn’t understand any of that. The stem won’t screw together. Looks broke to me.
OK. Are you sure you want to take this by yourself? More expeditious would be to give or ship it to a watch repair shop.
Anyway, if the broken stem cannot be removed from the crown then both part will have to be replaced. And then check  that the stem is held in the module correctly.  Honestly all that is way beyonf the level a watch owner can do., The pic you posted is too poor to read the markings on the module. All in all, consider buying a new watch, this can probably be sold easily for parts on Ebay.
Hi as jdm remarked the picture is not good enough for us to identify the movment. If possible a closer and clearer picture will be of great help. Once the movement is identified we will be able to point you in the right direction regarding the stem, thanks
If I would make a dearing guess that is an ETA 251.474, you can read the exact model of the movement under the most right coil.*
Or as they suggest take a new picture...
It was almost the same as I thought, the stem for that is easy to get, since I live in Europe Cousine in UK is a great source, but there probably are places in the US to get it too, otherwise I probably have one at home.
A tip is to buy atleast two if you never changed a stem before because it is a little bit tricky to cut it to the right lenght, almost everyone here probably cut one too short sometime.
The next step will be to take a shot of the stem on the crown or if you could see inside of it, when the stems snapps there sometimes will be a short bit of the threads inside of it. If there still is a bit you could try to gently to remove it, otherwise you need to buy a new crown too.
Your in luck, now it is time to grabb the pliers. Turn the crown gently back and forth to see if it gets loose, if not the stem is glued and you need to apply some heat onto the stem stump, I usually use a welding gun but i asume you dont have any so if you just quickly warm the stem with a lighter it may do the trick. Never try to force it too much.
Since you got the stem out already I guess you figured that part by youself.
One can be sure there is no bit left in the mevement since the stem is a "snubbnose"..
So the risky part here is to get the stump out from the crown, otherwise you already done the hard part.. getting the stem out..
Edited by HSL
Unfortunately I think you managed to break it a bit more, one have to be very carefull, there still is a bit left to grab on.
The end result should look little like this..
I saw i previously wrote welding gun, of course I mean soldering gun, sometimes I get other things mixed up while I make myself a Gin & Tonic..
1 hour ago, Merlynda said:
looking for a crown
Cousins UK has the largest and better described offer.
Again I recommend that you try well if the stem stump is held and works in the module otherwise the fault problem does not end with stem and crown.
    • Hi @Michael20 I am no furniture man my self but it’s just bits and pieces I have picked up over the years. It just takes patience when dealing with things like the cases but most are veneered plain wood. When they get damp and open up that is a problem
    • I often get an amp drop after i oil the stones with 9415, not sure what difference can be achieved with oiling the teeth.  I guess the oiling surface is very small on a tooth as opposed to on the stones a larger drop might have more drag as the teeth plow through it. I oil with a bristle from a brush now, strangely enough the last movement i oiled five escape teeth and the amp was much higher than i usually get , coincidence ?
    • Who'd have thought to look at the supposed compatible calibres ?  🤔 Frank did 😅
    • I recently helped my mentor to service 7 Seikos and he told me not to lubricate the pallets. His reason was from his experience from the advanced classes that he conducted, his students all ended up with worse amplitudes after oiling the pallets. I have to admit that I had the same problem when I oiled the exit jewel, like so many videos on YouTube show. I actually ended up with worse amplitude.  But now I oil the escapement by oiling the teeth of the escape wheel. I think Rolex used to train their technicians this way. I find that I get about 20° -40° increase in amplitude oiling the escapement this way. I've only started playing with epilame recently. I got a bottle from a Chinese seller on AliExpress. It's supposed to be Episurf Neo but everything on the bottle is in Chinese. When the bottle arrived, half of it had evaporated or leaked. And when I brushed on a thin layer on a mirror, it dries rather slowly and even feels a bit tacky. When I did the oil spread test, like my experience with stearic acid, the treated and untreated surface of the mirror yielded similar results. The contact angle of the oil drop looked about the same for both the treated and untreated surface. When I epilamed an actual pallet fork, the escapement was so sluggish that I couldn't even get 180° amplitude. I dunno if I got conned by the seller but the results are just not convincing.
    • I usually just use 2 pair of pliers to remove the roller ( just kidding  🤔 )  I want one,I have an adjustable free standing one. But i really like the little bradux tool that nips under the roller with two tapered jaws that lift it off. You can get under a scope with it to see in detail how the job is going. There is some technique involved to stop you chopping the staff, doesn't particularly matter if the staff is already broken but it naffs up the tool's jaws if you crunch the staff, and the jaws need to be in good shape to prevent damaging the roller. But well worth a try if you've never used one and you can find one that hasn't been misused or buy a one new. The trick is to keep one of your fingers between the two arms to soften the squeeze, with a little practice its a handy little to. I will now prepare myself for an onslaught of negative feedback on it 🤣
