Shallow screw head
Use a stone to grind the tip of the blade frontally so  to widen it to match the slot width. That will cause the tip sides to make a better wedge and grip. It is possible that you will have to keep that blade/driver for similar screws and use another for regular heads.
FYI we have a section where is considered polite for new members to introduce themselves.
   i just removed the rotor from my sieko AND noticed the shallow wide screw head.  i reshaped one of old drivers to fit ( try for 100% contact in  the slot ).    the sieko is well used and had a noise roter.  - worn bearing.  no sign wear yet,  so i used some special oil and it is silent now.   VIN
