Timex Q movement swap
philipk65
Hi Everyone,  I have a 1980 Timex Q quartz watch that was a graduation gift and hasn't worked in 20 years (battery corroded).
I bought a working one off of EBay and want to swap to movement. I've seen online all it takes is pulling the crown/stem out and the movement, face and all
comes right out. Not this timex. I looks like there is a ridge round the case and some sort of metal fingers at need to be bend to remove movement?
Any advice would be greatly appreciated!  Thanks!   Kevin
The 'metal fingers' hold the dial onto the movement..........
This watch, like most of, if not all, of Timex's early quartz watches , is a 'front loader', in that the movement comes out of the front of the case, after removing the crystal. On some the front bezel has to be prized off to remove the crystal, on others the acrylic crystal has to be removed with a crystal puller, like this:-
With these ones it is obvious as the crystal has a high dome and pronounced vertical section that protrudes above the watch case, that the jaws of the puller engage on....
Hi  Thats better although the one of the movement is a bit out of focus.  Judging by the dial there has been water/moisture ingress.    Is there a model number on the back.    It does look as though the movement is removed through the front.  As JohnD mentioned  you will need a crystal lifter to remove the crystal and then the movement.  I am not familiar with these at all, but to remove the stem look for a release lever, pull the stem out and observe how it is locked in place. Some require you to lift the release lever and others require a pair of tweezers to open the locking spring. I recall that it was shown in an earlier post so have alook via the search in the top right under timex.
  • 4 years later...
The pictures are showing the M42 movement in your grandfathers original watch.  I actually have one and it's a unique movement since it only advances once per minute so if you had it open and put a new battery in it you need to wait a minute before you hear the sound of the advance of the minute hand.  Timex only made them for two years. Notice it doesn't have a second hand because it's not needed.  You can find more information here on the movement https://17jewels.info/movements/t/timex/timex-m43/  I have attached a couple of pictures of my 1990 Quartz with the M42 movement.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
