Omega 3330 Service Manual
margolisd
Thanks for looking and sharing these. Sadly I've not been able to find the 3330 manual anywhere. I guess as it's quite a new movement Omega guard it very closely. I thought the new EU rules meant they had to share manuals and parts now.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
