Tommy Hilfiger watch pusher
Facsi
Hi. I have a Tommy Hilfiger watch that damaged the pusher a few months ago when it fell on the ground.
I opened the watch to try to fix the pusher because it is stuck in a pressed position. I tried pushing it back from the inside after removing the mechanism but it is very hard. I was going to try using a press to remove it but I don't know if the pusher is pressed or it is threaded.
The inside is just a pin with a circular lock.
How can I find this out?
For a watch of that value I assume that it's pressed in. From my past experience the likely reason for the pusher holding in is that the shaft is bent and preventing it from move moving smoothly in the pusher housing. Before looking to replace the pusher, I would press the shaft from inside the watch case to reset the pusher position and then check the angle of the pusher head. The circlip could be removed to release it entirely for examining the bent shaft and straightening it. I've even left a pusher assembled and grasped the pusher button and straightened it. I'm currently wearing a Speedmaster automatic Day-date that I corrected this way and it didn't affect water resistance.
Good luck!
Sent from my BBF100-2 using Tapatalk
  • 6 months later...
Thanks Lwayslate.
I saw your message back then. but I only could manage to remove it today. It was oxidized but all rust was removed.
Now the issue is the reason it was stuck: the housing for the button is just a little bent. Probably due to a fall. The button is perfect
What would be the best technique to unbent it? i can't think of any tools i have that would fit there.
Its stainless steel. So very hard...
hi tudor.
doing so the button would be useless, as if i had not fixed it.
I used silicone spray to lubrificate the rubber. the other button is working better than before. I also have a habit to avoid watches come near to water :)
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
