Rolex Submariner Case Opening Issue
clockboy
Just goes to show what a difference quality tools make , I was in the motor trade as a youngster and my knuckles and fingers soon learn't the difference  between quality tools and the not so good quality ones, I think the skin has only now grown back and that was about 30yrs ago since i left lol
They are great tools.
Top tip - use a poly bag under the watch, as the bezel or any perspex glass can be scratched otherwise. I found a poly bag to be thin enough to give a little protection but not so thick as to stop the watch sitting properly in the vice. This is because the watch can move slightly when you are turning the back off, and if you are exerting pressure downwards, which is natural, thats where scratches can happen :)
That is the same unit I have, the Horotec.  I work on lots of Seiko diver watches that have stuck case-backs and it has never failed me as Mark said you can purchase almost any die to fit it.  I absolutely recommend it.  I use the knock off Rolex dies with it as well and it works great.
Best of luck hiding it   it comes in a big box lol
Sincerely,
Jim
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
    • Thank you very much,T. I'll try turning the arbour from the clock face end very carefully in case I haven't reassembled the suspension block correctly (I had to make up a suspension spring using remnants of a broken one as I haven't been able to find an exact replacement online).
    • Hi murks a picture of the front as well would help,   By the size of the plate it was stuck to I would suggest a coin cell,  2030,  2015 all depends on the height of the cell. And the space when the back is fitted.         3 volt.
    • We seem to have gone a bit quiet on this ?  Do we all agree to ask Mark for some input on this matter, or is no-one really bothered.
