Click spring replacement
arnaudG
If you can identify the movement then you can probably just buy a new one.
Post some good clear close-up pics of the movement and make a note of any numbers or symbols on the movement plates, particularly on the main plate underneath the balance wheel and someone will likely be able to ID the movement and caliber.
OK so the movement is made by Cattin, and looks to be a caliber C66-CLD (but a C66 will be just fine as it's the same thing without the date). The part is #434 click spring.
Unfortunately both Cousins and Borel list that part as obsolete, which means they don't have it.
There is a complete movement currently on eBay here
and it looks like these movements were often to be found in Mortima watches so it's worth looking out for a scrapper to see if you can salvage the part you need.
Happy hunting :)
Hi ,that looks like to me a one jewelled version of the cattin 66 ,a popular 17 jewelled french movement of the era in a lot of dive watches from Mortima . I would say the click spring off a cattin 66 will fit your watchImage result for cattin 66 movement
Edited by Graziano
The Cattin 66 is a quite oddly constructed pin lever movement.
It uses 17 jewels, but two among them are without any function at all and are located on the dial side on top of the mainspring barrel.
The balance jewels are enclosed in a very “special” way: They are surrounded by large plasic frames. Maybe due to the red color, this looks quite nice, but it doesn’t offer any advantages to a metal jewel enclosing. Additionally, due to the lack of a shock protection, it makes the balance axle breaking quicky, if you drop the watch.
The complete gear system is located under one bridge and is not stacked. Since it consumes a lot of space, the cannon pinion must be driven indirectly. This is done like on Roskopf movement by the mainspring barrel, but unlike Roskopf movements, the hour hand is driven by a separate gear.
On the dial side, you also find a yoke winding system - an unusual detail for pin lever movements.That movement you have looks like a one jeweled version of the above .I love the old dive watches and have a few Mortimers with this movement they keep great time when looked after ,and are quiet rare hang on to it.........
Edited by Graziano
I guess I could go for this:
https://www.ebay.com/itm/MORTIMA-WATCH-NO-WORK-FOR-PARTS-MEN-S-CAL-CAT-C-66/223889087344?hash=item3420d45b70:g:GKsAAOSwhLReJwEj
I read somewhere that I could bend what left of the broken spring and make sure it can catch the ratchet wheel.
Could it work for the time being?
That's a cheap buy , if you are going to keep the watch you would have a donor movement to source further parts .You never know you may even buy another c66 movement watch one day ,and you'll have spares . They are getting harder to get ,I would buy that and replace the yoke winding spring .I would not try and bend it ,it may work but sometimes it can cause other problems down the track . But that's what I would do .good luck
Edited by Graziano
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
