Out of curiosity can someone recommend one single book that covers most (if not all) of the repairs for watches ? Would this be a candidate ?
I also have a copy of Practical Watch Repairing by Donald De Carle and from a beginner's perspective I think the Henry Fried volume is more comprehensive.  I throw it open to the more experienced members for their opinion...
Frank
Frank
    both books are good,     get more books.    when you become a "master mechanic"    sell um.   or save them for old age.  vin
    • I'm no expert, but I'd guess this one is for the bin. Looks like it's been tinkered with by someone armed with a hammer and chisel. When the pallet, escape wheel and balance are all damaged it's beyond repair isn't it? Or a new movement if the watch itself is of value.
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
    • Probably more than you need to know in these two vids, but sharing because I found them quite interesting. 🙂
    • And then the problem of the stud holder and regulator which are on the wrong sides of each other:   I am baffled as to how this will have happened?  They can't re rotated into place, the regulator pins stop the spring stud from moving past. I don't think I can remove the regulator and/or spring stud without a staking set?
    • Just to inform that this is not a shock protection, just end stone fixed in place by the spring.
