This watch probably moved from attic to attic for the past 40 years and most likely did not have much wrist time. The owner put a new battery in but the watch is misbehaving.
Depending on the position the display goes faint, on, off. The time cannot be set. I can pull the crown out, the seconds start flashing, pressing the top button does cycle through but I cannot set the time/date with the bottom button, sometimes the number is increased (very rarely), in most cases it will jump back to the seconds. The time changes randomly.
I don’t know much about digital/quartz watches so I haven’t even opened it.
Can this watch be resurrected?
Yes probably it can.
I would start with opening it and cleaning everything - then consider inspecting the circuit board for damage.
I found mine needed a new polarizing filter on the LCD.
I do have a spare circuit board somewhere if required. They come up on ebay as well.
In that condition restored its probably worth at least 125 GBP.
I didn’t want to delve into quartz at all, but it’s a challenge, I’ll give it a go.
How do I clean it? Horolene is a no-go and the only thing I have is rodico.
Hi  Cleaning these types of watches would be a mine field as they use varnishes on the pcb so materials such as any petroleum based spirits is a no no, Apart from using dry air carefully to remove dust.  In the old days carbon tetrachloride was avail able also Arkalone which we used in the factory for cleaning computer circuit boards Both now defunct under the harmfull chemicals legislation.
This guy here is a good enthusiast of digital watches, and he has quite a few videos regarding servicing them. I've just picked one of his videos, very complete, so if you want to see it and apply some of his methods, or check his channel ans see if there's any other interesting video for you.
It’s been partially disassembled and I must say it looks good except a little corrosion on the battery connector. I’m not so sure whether this would affect the behaviour of the watch.
See what you think and let me know whether I should pay attention to something else.
You can use IPA to clean the  battery leak and the contacts for the buttons, and the buttons themselves I guess, so they make a good contact when pressed.
I’ll go the chemist and see whether I can get the IPA, if not I’ll order it online.
I’ll probably need some silver compound  too.
Yeah give it a clean - alcohol/metho/spirits.
Solvents are no good - they eat the plastic/varnish.
Shellite also no good from what I read.
Give it a re-assemble and see if it works.
I gave it a good clean with IPA, assembled it and had the same problems. At one stage I was able to set the time, day and date but the case was not closed fully and when I pressed it together to close the small gap I run into the same issues. The calculator works fine but pressing the pushers does not.
There is part that looked meaningless to me and when I compared it to the image in the parts list for the C153A caliber I realised it was broken. It’s the positive battery connector. I’m hoping that replacing the part (found one on Ebay) will resolve the issue but it makes me wonder why it works at all?
Yes, I used IPA to clean it (99.9% alcohol)
I'll have to disassemble it once again. I didn't lubricate it and neither I cleaned it to a standard I'm happy with because I didn't know how many times I'd have to take it apart to get to the bottom of the problem. I'll also use polywatch to remove the scratches.
    • A good learning piece but think for the price of a new movement that's all it is. Probably just transfer the rotor if it's Citizen branded.
    • I'm no expert, but I'd guess this one is for the bin. Looks like it's been tinkered with by someone armed with a hammer and chisel. When the pallet, escape wheel and balance are all damaged it's beyond repair isn't it? Or a new movement if the watch itself is of value.
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
    • Probably more than you need to know in these two vids, but sharing because I found them quite interesting. 🙂
    • And then the problem of the stud holder and regulator which are on the wrong sides of each other:   I am baffled as to how this will have happened?  They can't re rotated into place, the regulator pins stop the spring stud from moving past. I don't think I can remove the regulator and/or spring stud without a staking set?
