I am fairly new to fixing watches I have a graves Express English lever when I rock the movement the balance wheel moves as it should but the escapement wheel does not turn (It is free) it apears that the escapement lever is not allowing it to move.Has anyone got a diagram of it or advice on how to fix
 Charlie
HI if     the balance moves freely and the fork moves freely and the movement is wound then there is a blockage in the train  First let down all the power on the mainspring , Once done remove balance and the fork. Now try the train wheels just jiggle them are they free if so put two turns on the winder, does the train move ok , If so, replace fork and balance and put some turns on the spring and try again, Does it work ?   If not its a strip down and check all the wheels mainspring pivots clean and re assemble this is the same if it works it will still require a strip down clean and lubricate.
If you're new to watch repair I would put this one aside for now. Full plate watches are not easy to work on, and there are zero spare parts for this watch- aside from making them. When you are really zooming on regular modern manual wind watches come back to this one.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
