Over Wound Question
Saying a watch is overwound is a fallacy.
If the spring is fully wound and the watch is not running it is a fundamental problem with the movement. It is impossible to say exactly what is wrong with the watch without examining it in detail. It could be something simple like solid oil gumming up the works, but it is more likely to be a broken pivot, jewel or some other mechanical issue.
I would guess they mean the mainspring is broken?
To be fair, it is a generic term that non-pro's use to self diagnose their watches when they go wrong. "My watch is over-wound"!
In other words - could be anything. If they could describe the exact symptom then you would have a better idea. For example - if the winder turns forever then the mainspring is likely broken. If it turns and flicks back then the click spring is gone. If it winds up fully but does't tick then..... and so on :)
Totally agree, it would be better over a pint! :-)
Now you are talking - don't tempt me! My NYR is to lose another 20lbs - lost 30lbs last year but gained back 10lbs over Christmas and new year, I blame the beer and cider, beer is now currently off the menu, and I am in complete withdrawal :(
Hopefully all it is is that the wheels are a bit gummed up, i usually wind down the main spring, then remove the pallet , then wind up the watch a tad to see how free the wheel train is, this usually tells me whats going on,
The pocket watch was delivered today and it is indeed a 6498. I was getting worried because I saw a similar pocket watch on eBay with a Unitas 6445 that looks almost exactly the same. At first glance I noticed the hairspring is pretty bent but will report back after disassembling. I'll be doing the TimeZone Level 1 course with this movement and might even get the chance to order my first part from the looks of it.
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
