Ok folks, I've gotten this far, I just need advice on removing the stem. This is a 50s vintage Timex 100. I believe the movement is a model 21. Thank you for any advice you have.
Edited by FLwatchguy73
many times I have wished that whoever put up that google drive did not. reson is the information is not complete. as there is no instruction for movment removal in the manuals.  The instructions came with the crystal tool.
you hold on to the stem with pliers and unscrew the crown.  do not pull off the dial.
a tip for when you insert the seconds hand is to rest the backside movement on a coin. this prevents the pinion from retracting down.
Notice how it is held in by the spring clip.
12 hours ago, FLwatchguy73 said:
you reveal another issue with google, @JerseyMo.... It's full of inaccurate information. I read on another site that the crown and stems were one piece and couldn't be undone. Thank you both @AndyHull and @JerseyMo:bow:
Some of the stems/crowns in other movements are one piece (perhaps the majority), and the crown does not come off, but there are a few Timex movements (this being a good example) where the crown does come off.
In the cases where the crown and stem are one piece however there is generally a screw or spring that holds the stem in place, so all of the mechanisms can all be removed from their cases relatively easily, one way or another, generally without removing the dial.
There is quite a bit of information out there, some of it accurate, and some not. I have yet to find a site that gives complete info on all of the movements.
Here is a little bit more about the various movements, incomplete, but worth a quick look.
https://en.wikibooks.org/wiki/Budget_Watch_Collecting/Timex_movements#Base_Model_22
Having said that, @JerseyMo and others here would be able to answer pretty much any question you may have about vintage Timex stuff.
Edited by AndyHull
That would be me :-)
What is posted is mostly what was on the old Timex forum, with some additions by me from info that I've accumulated. I know it's incomplete, but it's all I've been able to round up so far.
Happy to include any info that's not there, contributions welcome!
Cheers
Cheers
oh, I knew you had started putting these up on google drive all along amd I'm sure I created some of the scanned documents.
the Timex forum is gone... but I sure had fun oin there while it lsted.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
