For Those Who Work On Kinetics
Only have a closeup of mine.
The watch sits upright. You can use foam to wedge it so it stays put smack in the centre of each ring.
Took 4 days to fully charge mine.
Edit.
Its the base from this set.
Edited by ro63rto
Thank you ro63rto! I'll check those out on ebay, I believe it is what I was looking for!
Cheers,
Bob
One thing to point out though.
I have not opened it up to bypass the timer feature so every few hours i have to press the reset (red led) to resume charging. One day I'll get round to it.
I've only had one kinetic watch (a Seiko Arctura chrono), and had no trouble in keeping it running when it was off the wrist. When it did run down, it took a few hours to get it back to an even tick - rather than the 2-second jump that the second hand makes when it's underpowered - but apart from that it ran more or less continuously on a day's worth of normal wrist time..
It always seemed odd to me to save battery costs by buying a kinetic - and then use an electrically powered winder to keep it going! In the end I sold it as the chrono function was faulty, and got a solar powered Seiko instead. I much prefer solar power.
Are those obsolete now, or do they still make them?
I got mine from A.G.Thomas some time ago, but their website is such a mish mash, it would probably pay to phone them.
I don't think Seiko have ever officially sold them, I just think that occasionally the suppliers acquired them.
I have seen them in esslinger and ofrei, maybe even in borel but the price....the quote in my first post is from esslinger! Too rich for me and I don't even have one kinetic yet....although some will be refurbished soon. :)
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
