Help With Loose Movement
I picked up a nice vintage Longines off the internet (stole the strap for my other Longines) and while its a great watch and keeps wonderful time, there is an issue. When I wind the watch the entire movement kind of wobbles around as if it's not secure to the case. I'm not a watch maker, which is my first problem, but I like to tinker. I removed the case back and noticed that there are screws securing the movement to the movement ring, but no screws securing the ring to the case. However there are four tabs that are on the movement ring and what I assumed was that when you screw the case back down, the inside of the case back will apply pressure to those tabs and keep the movement snug.
However they aren't doing there job. I figured that over time (this is from the 1940s I think) the tabs have bent down ??? So I got the bright idea to try to take one of the tabs and gentle pry it up so it sat slightly higher and would make contact with the case back. Huge mistake as the tab just broke off. The other three are still in place.
Any suggestions on how to fix this issue? The watch runs fine other wise.
Thanks!
Sent from my mobile phone using Tapatalk
Hi,
Very nice watch, a real beauty, am not sure but it could be missing a rubber gasket/seal that would fit between the inner case edge and the movement ring, that would secure it but as I say am not sure as it is a Longines so I would have thought the movement would have been secured better..
Sorry I could not help much more, hopefully one of the other guys will be able to help
Best wishes
Darren
You are right in the sense that the 4 prongs apply pressure, holding the movement/dial against the crystal or case. This only takes care of one plane, in-out.
Sideways movement is usually achieved by having a tight fit between case/movement ring/movement. In you case you need to observe and see where the fit is loose. Is it between the ring and case or between ring and movement?
If the case is loose between the ring and movement you can either press a few dents in the movement ring (from outside inwards) to remove the play or you can shim the movement in place using a bit of old mainspring.
If the play is between the ring and case then there not much you can do.. try looking for an o-ring that will fit in the space between the movement ring and case, the o-ring doesn't have to be whole... 3-4 short bits spaced equally around the case will do.
Looking at your pictures, I think you're missing the inner bezel.. this would play a part in the dial/case interface. Is the inner caseback marked?
Note that if the movement is loose in the case there is possibility of the dial getting damaged. You dial looks good, maybe not original but probably an older redial.
HTH
Anil
"Help With Loose Movement"
Hi if the same in a couple of days, consult your GP. :)
:D   Sound bit of advice! I wouldn't expect less from this fine forum.
But I have a gut feeling that nebulight is asking about different KIND of movement!
Sorry, couldn't help it.
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
