Dear friends,
I've been looking at different Seikos 7T32 and they have appealed to me but the movement is not available (7T32). I'd love to restore one for my collection. Does anyone have any experience using an equivalent movement on those? Which is(are) it?
Thank you in advance,
Bob
Hi Bob, I had one of these for a couple of years and although a nice watch to look at, it's not the most reliable. I'm not alone with this assessment, one of my pals also had one which gave problems. In his case he handed it into a dealers and had a new movement fitted. This cost him the best part of £200 and it also failed after about eighteen months.
Back to mine. I bought it through EBay in need of repair, it stopped every day just as the date was changing. It turned out to be damaged tooth in the gearing that changes the date. I purchased the part from Cousins and completely stripped the movement before reassembly. Suffice to say that four stepper motors and lots of green plastic gears like sequins were a real challenge to get back together, especially when the half of the movement has to be snapped, not screwed, into place in one go.
I refinished the titanium case and strap and was well chuffed with the result. It was hardly off my wrist for the best part of two years then it started acting up. Time keeping was still excellent, but unfortunately the chronograph went wonky. Having worked on it once which was no real pleasure, and knowing that my pals watch was also knackered, it went back on EBay as spares or repairs.
I hope this helps you make up your mind.
If you must get a Seiko Quartz chronograph I can highly recommend one of these http://www.watcharama.com/skc020.htm
I bought one new back in the eighties and it has been running every day since! I'll take some pictures and post them in the near future.
hi Geo,
thank you for the excellent review. I appreciate it. I figure then I`ll be passing on this one.
Cheers,
Bob
  • 1 year later...
Here's the photo I promised, better late than never.  Model No. 7a28-7020.  This is still the watch I would keep if I could only have one.  For style, build quality, time keeping and reliability, it's right up there.  It has never been stopped apart from the occasional battery change, and is still worn on a regular basis.  Here's a site worth a look:  https://thespringbar.com/blogs/guides/seiko-7a28-collectors-guide
Hi Geo, actually that is a 7A38 since it has day and date windows. The 7A28 models don't have such complications.
The movement is also completely different from the 7Txx series, being mostly in metal and easier to service. Check this forum dedicated almost exclusively to the 7Axx family of watches (7A28 / 38 / 48):  www.seiko7a38.com
You're correct George, I should have put on my Optivisor when reading the inscription on the back.
I know the movement is completely different, it is incredibly well made. :)
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
