 By chaton do you mean the jewel or the endcap . If so they are probably standard incabloc . 179563 is that the one you are looking for ?
Yes the jewel 179563.
Thank you.
3 hours ago, watchweasol said:
Hi Mt Fixer  I was wrong, A senior moment. being an old git I suppose Inevitable.:D
No problem it was kind of you to reply regardless and I thank you for it.:)
Thank you.
Have a MST 520 . Must be the same jewel. If you want it i can send it to you? Pm me if so.
Will do
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
