Saved £1300
cdjswiss
This Sumiswald wall clock was stopping every day at 5 minutes to 11.
Our local clockmaker suggested a complete overhaul for CHF 2,000.00.
Five minutes to 11 o'clock ? ... why? That's just before the cam lever drops into the cam slot for the 11 o'clock chime. Perhaps a dirty cam? No, but a rather dry one.
An order to Cousins for some Moebus liquid grease. A smear of grease onto the cam outer edge.
Presto!  It has now run without stopping for 18 months.
Edited by cdjswiss
Lovely clock CDJ and a great result. I find it hard to believe that someone wanted to charge £1300 to service it. If it required a few major components manufactured the possibly, but just for a service????
Strip down, clean, re-bushing (the customer is always persuaded of the need) etc. This is an old clock and the offer was not surprising. For repair  to my antique English carriage clock the same clockmaker wouldn't touch it for less than CHF 2,500.00. All it needed was a new platform escapement from Cousins for £85. The clockmaker would have rebuilt the old escapement including cutting a new escape wheel.There are many rich Swiss who would willingly fork out these large sums. Hearing aids are another example CHF 8,000.00 for a pair! I buy from Paul in Keighley and do my own fitting.
.....and thats why the Swiss are rich, dont get me started on the price of the watches, tools, oils etc. etc.
Makes you wonder. You can buy a brand new Hermle Westminster chiming 8 Day Clock Movement  for £160.
The lash up,s I have come across beggars belief, epoxy glue, bushes squeezed tighter by the plate being punched, these being just two I encountered recently this year.
It,s sad really that the general public are being conned and these cowboys just give us genuine caring watch & clock repairs a poor reputation.
Perhaps that,s why these clocks quite literally keep turning up on my doorstep.
Ironically my interest is watches not clocks but a repair is a repair and I always try to do a good job.
    • Either of those ideas might work. Did you try putting a thin layer of rodico on the cocktail and then push the screw through it. Afterwards, soak in one dip
    • I would use some binding wire around the part before heating it. It protects the steel from being burned. I know that sounds strange, as you're going to heat it with a blowtorch, but if a part is thin and delicate the steel can literally burn away before your eyes, which isn't funny if you've put hours into the job. I bought some tools steel from Cousins a few years ago which turned out not to be tool steel, because it couldn't be hardened or tempered. I wasn't impressed, as I had spent two hours making the part for it to be useless.
    • Hi that’s what was meant by animal glue “ a glue made from animal products”. Ie bone , skin and other animal residues.  There was a place at Huntington YORK who used to boil down the ingredients. It stunk.   We used it in pellet form in a sort of Bain Marie on a gas ring  it was very good, didn’t think it was around any more with the modern glues,
    • It's back to the drawing board I'm afraid. As pointed out, the Rodico trick is so fiddly and my pin vice jaws don't close in union. I tried but the screw is so small it's hard to grip the screw in the Rodico without it moving all over the place while trying to get it in the vice. I started to shake too much so gave up before the screw flew off somewhere never to be found again.  I'm now thinking that maybe I could bond the screw on the end of a bit of peg wood and then dissolve the adhesive afterward.  I just had another thought🤔 I have some really small PCB drill bits maybe I could drill a small hole in peg wood and push the screw in, as stated I only need to get the screw started.  Another idea 🤣 Magnetize the screwdriver to hold the screw 🤔
    • Yeah there is a spring under there. Hopefully now I can source a screw for the click and the bridges! Thanks for your help!
