Saved £1300
cdjswiss
This Sumiswald wall clock was stopping every day at 5 minutes to 11.
Our local clockmaker suggested a complete overhaul for CHF 2,000.00.
Five minutes to 11 o'clock ? ... why? That's just before the cam lever drops into the cam slot for the 11 o'clock chime. Perhaps a dirty cam? No, but a rather dry one.
An order to Cousins for some Moebus liquid grease. A smear of grease onto the cam outer edge.
Presto!  It has now run without stopping for 18 months.
Edited by cdjswiss
Lovely clock CDJ and a great result. I find it hard to believe that someone wanted to charge £1300 to service it. If it required a few major components manufactured the possibly, but just for a service????
Strip down, clean, re-bushing (the customer is always persuaded of the need) etc. This is an old clock and the offer was not surprising. For repair  to my antique English carriage clock the same clockmaker wouldn't touch it for less than CHF 2,500.00. All it needed was a new platform escapement from Cousins for £85. The clockmaker would have rebuilt the old escapement including cutting a new escape wheel.There are many rich Swiss who would willingly fork out these large sums. Hearing aids are another example CHF 8,000.00 for a pair! I buy from Paul in Keighley and do my own fitting.
.....and thats why the Swiss are rich, dont get me started on the price of the watches, tools, oils etc. etc.
Makes you wonder. You can buy a brand new Hermle Westminster chiming 8 Day Clock Movement  for £160.
The lash up,s I have come across beggars belief, epoxy glue, bushes squeezed tighter by the plate being punched, these being just two I encountered recently this year.
It,s sad really that the general public are being conned and these cowboys just give us genuine caring watch & clock repairs a poor reputation.
Perhaps that,s why these clocks quite literally keep turning up on my doorstep.
Ironically my interest is watches not clocks but a repair is a repair and I always try to do a good job.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.  Watch this video. It think it'll give you an idea of the task ahead. From your 1st photo, I think you have a etachron type stud. Let me see if I can find a video on how to remove it from the arm.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
