Hello dear watchmakers.
I am working on a Unitas 6360 movement, Swiss made from 60s.
I definitely have to get new hairspring for this watch and I am searching the web to get the best deal..
On ebay, I found hairsprings for UT 6475 , UT 6310 and UT630. I wonder if these would work.
Also, is it OK to install screwed balance instead of non-screwed??
Any advice would be grateful.. Thank you!
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
