Good afternoon,
I'm Chris, new to the forum so greetings to all. Have replaced a faulty 2813 movement to find the new one stops the hour and minute hand when the hour hand is fitted, no dial. Works fine with the minute and seconds fitted, but the hour seems to be stalling the train. Checked that nothing is fouling the hand - am I right in believing this must be a faulty new movement ?
Thank you in advance.
Regards
Chris
Take the dial off and seat the hour hand and see if it runs.  (Assuming you have placed the dial.)  It could be that the hour hand flange is fouling the dial opening.  If so, you may need to carefully open the dial orifice a bit to allow the hour hand more room.
If you do not have a dial in place, seat the hour hand and take a very close look at the hour wheel and all of the motion works.
Good luck,
RMD
4 hours ago, Mrfixit said:
Works fine with the minute and seconds fitted, but the hour seems to be stalling the train. Checked that nothing is fouling the hand - am I right in believing this must be a faulty new movement?
No. As suggested above that is because the hour hand is fouling somewhere.
On the face of it it does sound like something fouling. But also check that hour wheel and its correct seating. The addition of dial washer and dial will keep the wheel in place but testing without dial it's easy for the wheel to lift slightly, not be seated correctly and the potential to affect the workings.
Edited by WatchMaker
Dose the movement turn the hour wheel? ( No hands fitted)
If you can,t tell by usual indicators,  I would wind  and get the movement runing,  Mark  ( The tube you mounted the hour hand on)  with a magic marker, ( no hand fitted) , check if the hour wheel has moved several hours later, thereby we can tell if fouling occurs as a result of pressing down on the hour hand/wheel.
Could you have pressed the hour hand too far down?
Best
Evening people, many thanks for your replies, really appreciated. Had another look at the movement, this time when fitting the hour hand didn't push it so far as to make it flush with the shaft it sits on, but left it slightly higher (no dial filled). This time it ran so refitted the dial and hands, re cased and working - for the moment ! Time to research canon pinions I think.
Kindest regards to all.
Chris
    • I am aware of one eBay seller who does cases for some American pocket watch sizes and also sells a case tube & sleeve assembly to work with American negative set keyless https://ebay.us/m/qa0ubk Also I have seen this seller many times but have never been clear on how they handle stems and crowns. https://ebay.us/m/4mhfEr I general though I don't think there are a lot of these cases out there, just a few sellers custom making them or adapting AliExpress cases somehow.
    • What type of glue you figure it was. I wonder if acetone dissolves super glue.
    • What's the movements so we know what size cases you're looking for and what are the setting requirements.
    • As I am getting close, I would like to know the total thickness of the bezel (top to bottom).  I am working on two solutions--one is thinner than the other.  The crystal sits pretty proud relative to the bezel, and seems consistent with the pictures I have seen.  But, actual measurements would be nice.
    • A little bit of superglue and you'll be good to go Although maybe if you had a laser welder you can weld the spring back together. Typically I've only seen it on blued steel Springs and on one occasion a modern spring? The modern watch was a Rolex watch that came and that was literally filled with rust including the barrel was filled with rust in the spring was in a whole bunch of little pieces. I have to wonder if that was an aftermarket mainspring . Then I'm attaching a PDF the Elgin watch company as you can see instigated a study in the 30s find out why mainsprings were breaking. I do though wonder if perhaps there may be a flaw in their study? One other things I wonder about is the metallurgy of the early steel Springs versus the later generation of blued steel Springs whether the metallurgy as part of the problem but in a case they did a study and have attaching a PDF. Because of the study any time I do anything with the blued steel spring when I actually cannot get something that's not blued. Once the spring is cleaned I'm very careful to not to touch the spring with my fingers because I don't want to have a problem with the chemicals on your fingers causing rust and I very carefully get lubrication back on the spring as fast as possible just to avoid these unpleasant situations. Then yes it is interesting one minute you of functional spring and the next minute you have lots of little pieces of spring. For my own personal Elgin pocket watch I put a steel spring and in this happened I'm also guessing that when one layer breaks it sends a cascading shockwave through the spring and that's why it breaks all the way across because after all there is a lot of energy in the spring when it breaks. Oh and my theory on the metallurgy is based on things have improved and for the most part I don't think I've seen a shattered spring in quite some time.   Elgin_Mainsprings.PDF
