Clumsy me knocked my beloved Seiko 5 off the desk onto a hard floor. I immediately stuck it on the timegrapher:
rate: -13; amplitude = 230-240; beat error: 1.0
Before the drop, I would get:
rate: -1; amplitude = 280-290; beat error: 0.2
It's a $100 watch, so not the end of the world, but still one of my favorites (and a good timekeeper to boot).
I'm guessing something in the escapement has been damaged, but I defer to the much more expert community here for the likely suspects.
Much Thanks.
Tom
Don't think the damaged is big . Probably only moved the arms on the balance bridge. Adjust the watch back to 0,2 beat error or better . And i think the amplitud will rise to 280.  No problem.
On 10/7/2019 at 1:51 PM, jdrichard said:
Perhaps a bend in one of the balance staff pivots
Sent from my GT-N5110 using Tapatalk
That would be easy to see on the timegrapher.  Would be impossible to get a straight line and think the amp would be lower then 230-240 .
Thanks everyone. I will attempt to adjust the arms on the bridge as soon as I am feeling less klutzy. I've done this a few times on other watches, and so far I haven't destroyed anything. :)
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
