2240 Chinese (I think) Stem Removal Help
Solved it!!!!! A post on the underside of the operating lever return was sitting on the wrong side of the spring. Due to the design it worked a bit, but not properly. Refitted the lever while retracting the spring and now it does what it should! I think you learn more if you solve a problem yourself rather than being told the answer. Now it's back in the wash, and see if I can get this thing up and running!
I asked ChatGPT's deep research mode about blue screws in Rolex without pointing to any particular source. After thinking for 10 minutes (deep research mode), it quoted your earlier conversation with ChatGPT: We are slowly breaking the Internet, post by post. Forums, populated with real people, are crucial!
Unlikely to run happy, you will see low amplitude, hindered oscilation, and awful timegrapher display. Cheaper to replace this balance complete with a new one. Regs
Did the effort twist the compass arms and bend the pins ? A soft rubber ball is the recommended thing to use, I mostly use a rubber bung fitted to a handle. But these from AliExpress look useful, and are cheap. -
It's from a 1" diameter pocket watch the dial of which says "West End Watch Co."; "Queen Anne"; "Bombay Calcutta". A local Charity shop has asked me to put it into saleable condition....
