Escapement pinion and wheel assembly
Nucejoe
How are escapement wheels and pinion assembled?
Would instaling the pinion onto the escape wheel on staking set, suffice?      Or the joint should also be shellaced?
I used to just glue the joint, but do expect some sort of corrossive effect from the glue.
Thanks in advance.
Hi,
wheels are rivetted onto the pinion.
Yes, if it is a new, never before used pinion.
Honestly, I am astonished on this question by you.
Frank
1 hour ago, praezis said:
Hi,
Frank
Thanks Frank, I guess it is back to gluing for me. This bunch I got are all used.
From experience escape wheels are friction fitted, usually onto a turned portion of the pinion leaves. The pinion is so small it's hard to form a rivet without introducing other issues; perhaps some makers 'peened' the leaves where they extend past the wheel. The forces are so light there friction works fine.
Balance staffs get rivetted very securely as they have to hold up to the installation and possible manipulation of the hairspring collet and roller table without shifting, not to mention truing of the balance.
Then of course train wheels need to be very secure, particularly the center wheel.
14 minutes ago, jdm said:
I have never heard or seen the recommendation of glueing wheels, pinions, etc with shellac or anything else. These should always be friction fit.
 I am seeking to improve on my work. I know gluing is bad practice, have seen evidence of corrosion from old glue on vinatge pieces.
The pinion at hand is so tiny, I can imagine friction fitting,   But rivetting???  Perhaps Frank had image of big pinion in mind.
Thanks jdm.          Regards joe.
Thank you Nickelsilver,  peening on staking set I suppose,  I feel I may damage the stakes, so I guess,  lots of light peens.
Edited by Nucejoe
Lots of light tapping
NOS escapement wheel and pinion of a wristwatch:
1. Seat of the wheel
2. Tips are peened and bent with a bored punch to rivet the wheel to the pinion.
If you want to re-use a pinion, you can try to flatten back the tips in the lathe, using a pivot file.
Frank
I understand that the following doesn't apply to  (all ?) Swiss making, but on contemporary Seiko pinions may not be riveted to wheels.
First, no wheel / pinion/ arbor / staff combo is considered to be separable.
On the left is the magic lever reduction wheel, on the right the escape wheel and here things get interesting (for the maniacal), the vi pinion teeth are really really small, but it seems to me they are not riveted?
Their diameter is (probably) the same as the central section of the pinion, which has been reduced to reduce mass possibly. Of course the wheels seats against a larger section.
Please disregard the dirtiness of the parts pictured, these are just from the scrap bin.
Edited by jdm
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
