Hi, Its a 20-30 years old wall clock. The brand is mentioned as Supreme (Made in Japan) I spend about 20 minutes and found how to remove hands. But now I can't separate the machine from the body. I attached photos of both sides. Please help.
This looks like it unscrews? usually a screwdriver in one of the slots is sufficient to unloosen.
This type of screw ring is often seen retaining the movement to the dial.
Anilv
Anilv
I tried turning both directions. But looks like it is fixed.
anilv is correct it unscrews from the center. A tool fits into both slots and you unscrew, you should be able to do that with a screwdriver with a decent blade fit. I would not worry too much, on how you remove the movement as long as you do so. You just buy a new movement and fit it, they come with all the little bits and pieces and you can even choose what style of hand you would like.
I'm moving this to the Clock Corner.
Thank You. I tried using a screw drive, but didn't work. You know the name for that tool?
Tap on the screwdriver with a little hammer or anything acting as hammer, gentle, numereous taps( impacts) will eventually break loose the nut.  You may have to tap on it a lot. Needless to say, impacts are to be applied in the direction that the loosens the nut.
You may also could grab the nut with a vice-grip or pliers, (on the outside) to loosen.
Some folks insert tweezers into both slots and turn, as long as the tweezers you use are strong enough and cheap.
Most movements have like a rubber washer between the movement and the back, this prevents the movement from moving about. They also sometimes stick like glue so a little force might be needed.
Hi To get to the works, remove the two cross head screws on the back and carefully prise the back cover off, some have lugs on each side nwhich you release , but looking at the pictures it is a prise off back. they are quite easy to do and putting them back on is easy too just be carefull all is lined up and in the correct slot before closing. I have done a lot of these quartz movements and repaired most of them no problem. If it is beyond hope they are cheap enough to buy although the better quality ones are better units, Herchinger, UTS, Keinzle, Seiko etc.  good luck
Hi Old Hippy
  One assumes by the pictures he has done that already, But you are correct it will remove the back to expose the gear work. If he follows yours and Joe's  advise No Problem.      :D Sometimes we assume too much
Note that when sourcing a movement they come in different heights to cater to different dial materials.. Not immediately evident when buying off the internet.
Anilv
    • I remember playing with asbestos wire insultaion when I was a kid (remember the cool fluffy white stuff?) and I've been breathing fine dust particles in my woodworking shop for years, so I'm probably toast either way, but I don't want any of this radioactive dust anywhere near my kids.
    • Its good to understand how and why demagnetisers work. These two pieces of text explain in basic terms how ferrous metal is affected by magnetism and why they can retain some of those properties.  The cheap demagnetiser is actually a magnetiser,but is used in a way that can remove the weak magnetic properties that a steel has gained through magnetic field exposure.  As steel is drawn further away from the device, the magnetic fields around it become progressively weaker and more -irregular- . This causes the disruption of the atomic and subatomic alignments within the steel that make it magnetised. So also moving the steel  through different orientations as its pulled away could actually improve that process. I still use my first cheap set of drivers, I notice very little difference in the way of feel between them and a set of preowned Bergeon I use, blade quality is more important. Tweezers have more variables, but again they don't have to be expensive to work well. My most used tweezers are my cheapest, but then I never use any pair that I haven't modified in some way.
    • Yeah, agree on the rotation thing - I'll use this as my work beater, and rotate between the others outside of that I think.  The 'problem' is with these that in many cases the parts are worth more separately than in a bad example: assume the bezel, dial and movement the same seller is getting rid of came from the same watch... If he sells them all he'll get a similar price to a really good condition example.  There's a good side to that though - it means you can often find the odd bit you need. And I paid less for this case and crystal assembly than I did for a crystal and dial holding ring I bought for another project, so there's still value to be had occasionally.
    • Cheap ginger counters will tell you if you have radium, but don't waste your money and don't worry about it.
    • Nice rescue. I like when a few with heavy patina are worn in rotation with nicer watches of a collection. Frankens, too so long as they aren’t passed off as something else. My experience with these Seikos is they tended to disintegrate on their own so finding correct parts to put an original together is near impossible…
