I have a Pulsar project watch. It has a Y563a movement. The stem and crown is really worn. And  I was wondering if there is a replacement movement for it to use as parts etc.
Thanks
If it works you don't need a new mov't but just a Seiko 354.576 stem, and an adaptable crown. Both items are available from Cousins UK.
Note, even quartz mov't would need service but most people does not want to take an expense that is greater than the cost of a new watch.
Edited by jdm
  • Similar Content
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
