I have a Seiko, marked on the case back as 7019 - 7060, which I would like to CO&A.
Can anyone tell me how I could find  a video walkthrough to guide me ?
Many thanks, Mike
Seiko 70xx series are my favourite movements, there are lots of information on the web about them.
The "My Retro Watches" youtube channel have a tutorial on the 7025, which is quite similar but with only date complication while the 7019 has date/day. There is a video of the disassembly and two videos on the assembly.
Liani has a good tutorial on the assembly of the 7009, which is exactly the same as the 7019 but in yours there are two incablocs more than in the 7009.
And finally I'm attaching the 7019 technical guide that you need for the dial side, and the 7005 technical guide you'll need for the train wheel side.
Hope this helps.
Seiko 7019A - Technical Guide (HQ).pdf Seiko 7005A - Technical Guide (HQ).pdf
Hope this helps.
Seiko 7019A - Technical Guide (HQ).pdf 1.08 MB · 0 downloads Seiko 7005A - Technical Guide (HQ).pdf 1.77 MB · 0 downloads
This post is tutorial by itself.
    • You could try a soft-solder repair on that
    • Hi Logan, welcome to the forum 👍
    • So I recently picked up a slim 6105 which had a badly damaged dial (posted in another thread). I couldn't really live with that given I had another dial handy, also in not great condition but with added bonus of having a better lume job and actually being fully attached to the dial plate!  So what to do with that damaged dial - I tend to think they should be in watches. Well...  A 6105 mid case and crystal assembly punt arrived from Italy yesterday, which I've frankened back into a working piece with the dial... Damaged dial now sits behind damaged crystal in an original case, currently powered by 6106 (with a 6106 caseback on to reflect this... I've cleaned up the original crystal up to a point, but kept it fairly beaten to distract me from the dial, my markers and it's not very satisfying lume job - it's not awful but it's glossy which I don't like. Also has a 6139 bezel on it for now because that's all I could find - I couldn't live with it naked and don't mind it tbh, though will keep an eye out as ever.  So yes, here you go - another 6105 (almost!) back to life. I'll also keep my eye out for the correct movement and perhaps a better dial in time. Caseback might prove tricky/expensive. I know Frankens aren't to everyone's taste but I do enjoy getting these back into working form. Better a working/worn watch than a sat in parts draws imo. And the good news here is that, thanks to the repro service crown, this is the only one I have I could actually feel safe to swim in!
    • I suppose the first question is have you got the correct replacement stem. If you've removed it in the setting position then you could try pressing the button while inserting the stem. Other than that it's a case of possible strip down to get to the setting lever.
