Question About Old Watchmakers Desk
jdrichard
I was asked by the curator of the Canadian Clockmakers Museum what the small pocket on the lower right side of the desk is used for. It is next the the small poster and bottom right part of the desk, just below the desk top and about 3 inches wide by 6 inches tall.7d72dfd66397c90260c86bbe01df29e8.jpg
I will look this up. What specifically did they use it for?
They would load a bristle brush with it and brush down the parts. Sounds crazy I know, but that was part of good cleaning procedure 120 something years ago.
Goodrich's book The Watchmaker's Lathe its Use and Abuse has and illustration describing the chalk hole.
Thanks. I have that book and will look this up
Sent from my GT-N5110 using Tapatalk
13 hours ago, jdrichard said:
It’s just a square opening in the desk???
    i was looking at something else on the bench top !!!      put a circle around something on the bench top,   i'll try again - vin
For those who are curious, French chalk is basically magnesium silicate, talc. It's the lowest number on the Mohs scale for minerals.
Another mineral traditionally used in watchmaking is Spanish powder, or blanc de meudon or blanc d'espagne. This is calcium carbonate (primarily), slightly more aggressive as an abrasive. On a watch with gilded plates and bridges, when they are tarnished/stained and unaffected by normal cleaning methods, this stuff can be rubbed on wet with fingers or brush. It does an amazing job of brightening the parts, without leaving a scratch. Calcium carbonate is the main component of blackboard chalk, so if your local drugstore doesn't have it* crush some up and give it a try.
*we're really spoiled in my area with a drugstore thathas all kinds of cool stuff. Just got silver nitrate there for a new batch of dial silvering powder.
Again, thanks very much. I will pass this info along to the curator of the clock museum.
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
