Where can I download the C07.121 movement decomposition diagram? What is the reason why the movement of the watch is particularly low after the watch is cleaned? Do the plastic parts inside the movement need to be cleaned?
By rjenkinsgb · Posted
Two pins or screwdrivers angled out slightly, pressing through from the barrel centre from the opposite side so they contact just clear of the hole in the lid? eg. Strap pin driver needles or similar.
