Damaged screw head
Hi.  I picked up a fossil watch for a couple of pounds that hopefully only needs a battery, but one of the screws on the back is almost rounded off and doesn’t want to budge.  What’s the best way to deal with this?  The case is plastic so the screw is not rusted in.  I’ve resisted the temptation to put any sort of lubricant on it until I know what I’m doing.  Spa you suggestions would be gratefully received.  Thanks,  Al.
Hi  If the screw head is accesible try to cut a groouve in it with a fine knife edge  file to ceate a slot. Its not beyond some people to glue in a duff screw.  With a plastic case be very careful what you use to loosen the screw.  Be assured some body on the forum has had the same problem and will know of the way to proceed. good luck
Thank you for the reply.  Its a bit of an odd solution, but I wonder if anyone has tried solder to build up the screw or even soldering a screwdriver to the screw to gain grip.  I’ve got a colleague who can solder joints that I can barely see, so if it’s worth trying, I know just the man to ask.  Good idea, or not?
Hi  trying to solder a screw which is encased in plastic is frought with danger as the heat from the iron would cause the plastic to melt and worst case ruin the watch  proceed with extreeme caution if you follow that route. Another possible is to use a dremel and drill the screwhead off leaving a small stub to be removed with pliers
Thanks again for the replies.  I’d arrived at the “drill it out” solution but I’m still reluctant in case I can’t get the stub out.  I suppose, worse case it may end up with 3 screws holding the back on which isn’t the end of the world.  I hope it only needs a battery. Cheers.
Being plastic it shouldn't be overly tight. You can try using a flat blade driver with a sharp edge to help provide the grip on the edges as you loosen.
If it won't budge at all then carefully and slowly grind the had with a dremel. This will leave a stub protruding once the back is removed which should come out easily.
In assuming you've loosened the other screws and confirmed it is screwed down and they're not moulded in cosmetic heads?
This often happens with fashion watches and they're a pop off case back.
13 minutes ago, mlfloyd1 said:
By some screw extractors from Esslinger.
A screw extractor may work (assuming it's a real screw) but is kind of pricey for an one-off job on a doubtful watch..
BTW Esslinger is an US seller.. I gather the OP is in the UK.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
