Time to Jump Aboard
SteveK
Hi Everyone, Ive been an avid reader of the forum for quite a while and finally today I thought I should join in the fun.
I hail from Bradford, but via lots of different European cities, I eventually settled in Wakefield, West Yorkshire.
I've been a tinkerer with watches for quite a while, but this year I've decided to get some proper tools and set myself a target of learning to dismantle and rebuild some old watches (wrist and pocket variety) I also have an old family heirloom pendulum clock that stopped some years ago, which I'm tempted to have a go at !
Its basics for me I'm afraid, so no doubt there will be the obligatory silly and daft questions....I know there are some knowledgeable people on here, so you will have to forgive the naivety of my questions, but hey, we all have to start somewhere
Nice to be here
Steve
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
