I just received 2 new books today, both by Archie Perkins and I'm very happy with them.
I already had his first book ' The Modern Watchmakers Lathe and How to Use it'
and today I received
Antique watch Restoration Volume 1 and Volume 2
These books are not cheap but I'm very happy with them, if you want to learn how to repair antique watches these are the books you need.
Volume 1 Starts with 34 pages on just how to strip down and clean an English Fusee Lever Watch, followed by a chapter on repairing or making watch Fusee chains and then several other chapters covering how to make Clicks, Ratchwheels, Fusee clicks and Maintaining clicks, repairing fusee barrels.
It then has several other chapters on how to cut wheels and finish winding wheels with snail patterns, rayed patterns and even how to use a rose engine to make the patterns on the winding and ratchet wheels. I know someone who has made their own rose engine to make silver watch dials, so I can see me having a chat with him in the future.
Volume Two goes into how to set jewels in antique watches, then the verge escapement and how to make a new verge escape wheel as well as verge balance staffs, it also goes in depth on repairing duplex escapements, cylinder escapements, chronometer escapements, detached lever escapements, making new pallet forks, roller tables, pallet stnes and jewels and even balance wheels and screws. I don't have all the tools needed or the skill to do all this work, but it does give me something to aim at. :)
There is also a book 3 that goes very much into detail on replacing, repairing and making all types of hairsprings, but I didn't get this book as I decided that was way above my current skill level.
If you are all interested in restoring antique watches where you will likely have to fabricate some parts yourself I do very much recommend these books.
Good show !I only have 2 books.   good enough for vintage watches.   I should buy more if I want to take my speed master apart.   videos are o k but I like books.  vin
I'm a self confessed bookaholic, not just Horology books, but books on model engineering, jewellery making,woodworking, restoring classic cameras, gardening, cooking, brewing etc.
Basically if its a book on how to make or fix something I probably have atleast 1 book on it. I've even got books on how to make books. :D (book binding that is not writing a book)
    Camera books?   I have a few,   and on old watches,     and electronic (like accutron) BUT,   " I hate electronics".   cheers,  vin
Archie's stuff is fantastic. I think the books are or in large part are a collection of his ongoing series of articles he did for the Horological Times. Used to have the whole set of magazines and gave them away when I moved to Europe... dangit! So much info, there were some terrific articles on timing by Newton Noel and a dozen other watch gods.
I'll have to get the books now.
    • Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!).  So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
