I have a nice case and dial so decided to make a custom watch for mrs eezy with a new Miyota module.
No dial feet so I used sticky dial pads. I put it all together, it worked fine and looked good so left it on my bench for a few days with the back off. Eventually decided it was OK, put the back on and presented it to mrs eezy. It ran for about 24 hours before it stopped so I reset the time and ran it for a day or so. She wore it and it stopped again.
So further investigations and I find if I hold the watch vertical and tap it, the hour hand moves. The hands are new and not loose so I start thinking.
Conclusion:- The dial is not flat, it's convex, but the module is flat meaning the edges of the module are touching the dial but the hour wheel has a gap above it allowing it to jump out of mesh, even though I inserted the wavy washer.
Ah well, a novice error I guess :)
7 minutes ago, AndyHull said:
Can't you simply shim it with another washer?
Yes but those washers are so thin that 1 won't make much difference.
I've since had a thought that I could put another wavy washer on the other way up and that should work. I could shim it with anything but it's about calculating the size of the gap.
Hi  unfortunatly shimming in this case will be a matter of trial and error to achieve the correct gap. Try putting a bit of rodico under the dial then fitting it then remove dial and measure the thickness of the rodico after being squashed you will be near the size required
36 minutes ago, yankeedog said:
Plastic is nice...but it doesn't give you an excuse to have a cold one.
Actually I was trying to work out if I could use the top off a vodka bottle.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
