Rolex Cal 1560
Legarm
Update. All put back together bar the case.
On test at moment and has not lost a second in the hour since putting hands back on.
A few pics as I went along to see the balance guard in place and not now fouling the hairspring. If you ever work on one of these the Balance guard has a screwdriver slot to swing it away from the hairspring. I had to remove it to release the hairspring.
This seems to have been the culprit for the massive gain in time.
I shall hopefully re-case the movement tomorrow.
It' a bit of a shame that whoever serviced this previously did not take more care of the face and hands as they carry quite a few knocks & dings.
Thanks for all the nice comments.
Keith....
Nice job, Keith (Legarm). Looking good and amazingly clean!...and the hands are not too bad.  If you are not happy with them you can always refinish/relume 'em. I don't think it should disrupt the over all looks of the watch by doing it. I usually, if painting is also needed, use Testors paint. The lume I get from ofrei which is, according to other people, the best so far. All that said, I don't know if I want to do that to this nice Rolex though. Love to see the cased movement!
Cheers,
Bob
Thanks Bob.
Hope to re-case it tomorrow. Have got a bit of work to do on the bracelet as it has had the wrong diameter spring bars fitted in the past and the end pieces have become distorted.
I shall post pics of my final effort, as soon as it's complete.
Well, here it is, finished. Bracelet fixed and no longer flapping about at the lugs.
I don't know if any one knows a fix for the Bezel as it is nigh on impossible to turn. I have installed it with the plate that was on there originally as it looked new. Take the plate away and it's too loose.
Anyway pics as promised.
From gaining 8 hrs a day , I'v got it to 10secs which will do for me. Mind you this is nearly 50 years old so it's not too bad.
My favourite watch in the whole wide world & I have one too. This is the 1675 PCG (Pointed Crown Guard) or 'corning' quite a sort after model with the horned crown guards, small GMT hand and chapter ring dial. It is a early 1960's model.
Problem is the bracelet is wrong for this model, should be on a rivet or jubilee. None the less, a cracking watch and a cracking job you've done on it.
Nice one!
Hi Keith, I had a problem with a couple of Seiko divers. Although they are no Rolex, they use a similar ring. On one, I put some silicon grease all over the friction surfaces and it started moving properly. The other one had the wrong crystal -- too high -- so I had to install a new, lower one (2.5mm to 2.00 mm ). Maybe a fix of this sort may work?
Cheers,
Bob
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
