Hello,
The problem I am having is that when the watch is upside down the hour wheel seems to move out form its position and turns freely, so it change hour every time I look to it, minute hand is ok. Movement is an ETA 2784 and I mounted it without dial washer, could that be the cause?
I have reinstalled the hands like 20 time and screw the clamps tight so the hour wheel have no room to move out, but it keeps ocurring.
6 minutes ago, panchoskywalker said:
Hello,
Its happened to me the few times that I forget to put the dial washer. You've got to remove the hands and dial and put that washer in.
J
Put the dial washer back in. Make sure the gap between the dial and mainplate is smallest,  whilst the hour wheel turns unimpeded.
The clamp may cuts a groove on the dial feet, which may need to be filed flat.
