A Busy Weekend
I just spent the weekend learning 3D modelling. My motive is to further enhance and illustrate watch repair techniques using 3d animations and after a weekend of learning (thanks to Lynda.Com) I have made my first wheel.
I think it looks quite good so far :)
Good stuff Mark - have you seen this site, by the way?
https://grabcad.com
I'm a member - not that I use any CADCAM software, but it's a fascinating place with lots of  good stuff in it.
Here's a sample of what you can see for free: https://grabcad.com/library/eta-6497-1-complete-watch-movement
Edited by WillFly
Will, you are an absolute star mate!
I did not know about this site at all - 3D and CAD are so new to me, but I am getting the bug.
And it's also interesting to me because the big project I am working on, will partly be based around the 6497.
Brilliant stuff :)
On a Mac go to preferences, tick the "Show Develop in menu bar" then Enable WebGL. .
This allows users to see the 3d files in all the different views, I could play with this for hours!!!
Sounds cool. Maybe i'm going crazy - but I can't see that option?
The only 3D program I have used was an early version of Autodesk Inventor. It's great when you can produce something that anyone can recognise before you make it. Not everyone can get their heads around 2D drawings. I'm following this thread with great interest!
This is actually quite addictive. Was going to leave it until next weekend, but decided to make a setting lever spring after supper this evening. It's coming together quite well.
Should have my own 6497 built within a few years at this rate :D
    • Date (day) CAN be moved without issues from the crown (position 1) but it CAN NOT be moved by rotating the crown (position 2), nor does it move in a normal 24hr. cycle. Clock functions otherwise withiut issues. Brand new Renata. Thanks, V.
    • Visually pocket watches suit some people. Having bigger parts to work with makes things a little easier to understand, the con to this is older timepieces that have been messed around with. Teachers recommend starting with something new and in good working order, this way if it doesn't run after you have serviced it then you are only looking for a fault that you created. That didn't suit me though because I'm quite mad with a little crazy mixed in 🤪
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
