Landeron 48 reset problem - stumped!
Yes I think blue thread locker would help you out here. You will lose the safety mechanism if the mainspring snaps, which risks damage to train wheel teeth. But your watch might run. You can maybe try inserting a hair inside the pinion and threading it on. That might give it just enough to grab hold without thread locker. Or a tiny piece of superfine copper wire, a strand from some stranded electronics wire.
This late '60's / early '70's Elgin compressor style watch gave me a few problems but was able to get it sorted in the end.
You mean you've lost the rotor bearing as it's all one piece? Photos would help.
It's a spare from another watch. It's 0.5mm Dia. spring steel if you want to make one.
