Take of the cap of the juvels
Cheers mates!
Would like to hear how you people do when you have to remove the capstone on the juvels in the movment ??
Is it an okay way to do it this way:
I put i uside down on some radico, and take very thin needle an push out the capstone gentle, then I turn in right side up, and put an small dash of right type of oil in the center, and put back the capstone the right way.
Comments on that..
 Good day to ya all...
No cleaning at all !!!?? Refer to my incomplete thread  titled" tips on safe removal cleaning installation of fidly cab stones
To clean end stone's flat surface, place a piece of cardboard or thick paper with honey comb rough surface on a flat anvil or flat surface, place end stone flat surface on top of the paper, pour some lighter fluid on paper, hold cab stone down with finger and rub the stone on wet surface, press down on stone  as hard as you like, you will be surprised how shiny the flat surface of stone turns out.
Some tiny pieces of the cardboard aggregates around the stone which may not be visible at regulare magnification, to rinse that off , drop the stone in lighter fluid, remove stone with a clean tea spoon or tools you like.ready to be oiled.
Pegging the holes in jewels is beyound
22 minutes ago, arkobugg said:
And my qestion was actually how to separat the cap stone from the rest....
Like you, I use Rodico. Usually, the end stone sticks to the Rodico so no need to poke it. However, if the end stone won't release from the jewel hole setting I place the entire setting in naphtha (which I'll eventually do anyway). If the flat surface of the end stone isn't clean enough after ultrasonic cleaning I use my favourite tool which is a fibreglass scratch brush. It's a bit fiddly, as I need to hold the end stone with tweezers while brushing it, but with a bit of practice it works really well and removes every last bit of oil and dirt (40X magnification stereo microscope). Finally, I rinse it in IPA while brushing it lightly with a regular small art brush.
In case the stone dosn,t come off, I drop the whole jewels assembly in a jar add little lighter fluid or  any fluid in which oil disloves, close the lid and rotate the jar to get the fluid circle few turns around, the cab comes off from chaton.
I use dark color jars( ladies makeup jars)  which lets me see the cab in contrast.
In extreme case of a real stubburn end stone, I use balance with one broken pivot.
Insert the good pivot through the holes of chaton and that of the jewel, flip over to place the end stone on cardboard, press the pivot to push the end stone out and released from chaton.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
