Value of long case clock
clockboy
Other clocks of his clearly survive.
See: www.sellingantiques.co.uk/333369/georgian-moon-phase-longcase-clock-by-edward-powell-of-bristol/ and www.antiques-atlas.com/antique/georgian_moon_phase_longcase_clock_by_edward_powel/as579a295 (same clock I think but better picture and a price given - though subsequently reduced).  The retail price is obviously in excess of what a seller would get, sometimes ridiculously so.
A more realistic source for guide values is often eBay.  If you check on longcase clocks pre-1900 for a day or two you should get a reasonable idea of values of very similar timepieces.
Regards,
My friend is going to take pics of the movement to establish if it is the original. Once this is done it should be possible to get an approx. value. I know whats coming next can you service/fix it and I would love to do that but my workshop is just too small to handle long case clocks.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
    • Yep, that's exactly how it should fit. The reamer shank is tapered and the socket in the spindle is also tapered so that the one centers in the other and is gripped tightly. If there is any wobble when the reamer is seated as far it will go then there is a problem. The cross hole in the spindle is to allow you the push the reamer back out again. If the reamer seated much deeper then it would limit the access for pushing it back out again. Here is one of mine for comparison.
