I am servicing a Lancaster Prescot pocket watch. The main spring has lost much of its power and needs to be replaced. Does anyone know where I can get one from?
Many thanks
You need to take measurements first (strength & length) and what style of end it has, then check out the supply houses such as Cousins. I have a "General Resorts" catalogue and I can look it up and give you it's "GR" ref number.
GENERALE RESSORTS
Search width (strength), height (fit in barrel), length and/or barrel diameter; on Cousinsuk Web page. Make sure you have the right barrel hook end or you will need to modify it...which I have done several times.
Sent from my GT-N5110 using Tapatalk
