seikos three
yankeedog
Hello All,
                  Just staying out of trouble today with some seikos, that were purchased for parts from a vendor in The Netherlands.Starting with the one one the left, the movement was rusted beyond practical repair. I replaced it with an NOS Seth Thomas branded 7009 The one in the center was in similar condition. Not a thing is matching on this one, the case and the back don't match for one thing.The hands and movement were pirated out of westclox automatic with a ghastly  chrome case .it was a utc branded 7009 equivalent, 7005  calendar parts were swapped over so movement could work with the dial and case. Totally Franken, but the watch was a lost cause when I got it.The results I think are pretty good. The one on the right was a relatively unmolested 6109 , except for the fact that the previous owner had glued some luminous material to the indexes.It looked awful, some of the residue is still on the dial. The problem with them all, and the two remaining on my bench was gasketing, they were improperly sealed and all suffered to some degree from water , most likely sweat intrusion. I will have to look into proper gaskets for them. Thanks for looking. YD
Pretty impressive. There's something totally satisfying about bringing a watch back from a certain trip to the landfill. When properly sealed, any of those will make a great beater to wear while working in the yard or any other 'sweaty' activity. My hat's off to you.
Were that I was as good at avoiding trouble. I just collected a Wenger SeaForce Arctic special edition from the mailbox. Oy! It's a beaut. My poor bank account......
I have a bit of a soft spot for Seiko automatics, and have picked up a couple of basket cases. They clean up nicely, assuming they haven't been too badly molested, and tend to survive many years of servicing neglect that might prove fatal to a less robust movement.
The Citizen calibers ( 0201 etc (and by association HMT 0200 and 6501 and Alwyn (Seiko movements) ) also put up with a lot, and still battle on, as can be seen by the large number of them that turn up on ebay from India with garishly repainted dials or delusions of grandeur (claiming to be a Fortis, Tissot or some such).
    • Did you have a look under the ballance? Often the movement maker/number is hidden there.
    • I wonder if 9415 is based on a base oil of 941? it's interesting what questions bring and the tech sheet answers it's the viscosity of the base oil. Then the impact? There is something we're missing here for that which would have a big influence on all of the house image above is 9514 image below is 941.then always interesting when specifications do not exactly agree? They ledge above for 941 indicates 110 viscosity but the image off the spec sheet is slightly less but I guess close enough   my understanding of the concern of too much 9415 is as we know the loss of amplitude. But why do we have a loss of amplitude? So impact it's basically oil should be very slippery. But what about non-impact? Like the edges of the escape wheel? Another thing that comes to play here is the shape of the escape wheel itself. Notice on the last a more vintage escape wheel with just a flat surface whereas the modern escape wheels usually made out of steel versus grass much much thinner their contact areas greatly been reduced and sometimes I think there even slightly curved. So is it conceivable at everything that isn't a flat surface on impact is going to be sticky? So this is where the shape of the escape wheel will have a big impact literally on how slippery things are. Oh and for all of you obsessed with worrying about too much 9415 I never worry about it because typically I'm doing pocket watches and it doesn't seem to be an issue at all. on the other hand I'm much more concerned about a watch that keeps time for 24 hours as opposed to the concern of the group of keeping amplitude for 24 hours. Then yes some pocket watches have steel escape wheels and do look like the escape wheel on the right.
    • your balance wheel looks interesting in the watch and because it's at an angle it's changing things a little bit. in other words they hairspring is not centered between the regulator pin in the boot and I also noticed your terminal curve is lacking apparently by design? Because if you look in the second image you'll notice yes there's a terminal curve but not as aggressive a one as you normally see on watches at least most watches.   then in all of your images it looks like the boot isn't quite back where it's supposed to be? out of curiosity how did you remove your balance complete and clear the regulator pin? then just in case you weren't aware it rotates out of the way so you can remove the balance complete without bending the pin. Then it's rotated back exactly 90° and yours looks like it's off by just a little bit in the original image and I'm assuming that you just been the pin out of the way? it's always interesting in horology is the variations in the things. Like the image I have above does have a terminal curve but not the most aggressive and yours is even less but that is the way the watch was made. Then the spacing between the regulator pin in the boot should be relatively small basically if you had two pieces of the thickness of your hairspring that's how much space should be there like in this image. But oftentimes watch manufacturers do not necessarily follow the rules
    • Yep i can see where you're going with that one Rich.  Sooo now that I've frightened the OP into submission 😁. Chief i do apologise for some reason unbeknown to myself I'm in a happy silly mood. So seriously to identify the movement lets have a look at the dial side, learning this part is straightforward, just need a little logic and something called the # BESTFIT BOOKS # . Or the other non American equivalents.
    • I can definitely see elephant and aardvark and possibly some sort of bird with a large beak 🤣 anyway I'll have a go of getting it flipped over tonight and send some pics
