Hello all, I can't find the technical sheet for the above movement, I've tried cousins and ranft,  but no luck.
I've also tried esa and eta.
Hope you can help.
Thanks.
If the AS 536.121 looks like the quarts movement you show in the picture I can say it's a ESA 9362 also known as ETA 521.111.
You find the tech sheet here.
Some pics from my specimen of the movement below...
